bleeding brakes?
Old 04-20-05, 06:28 AM
blaznsc4
blaznsc4's Avatar
Default bleeding brakes?
anyone know the procedure on how to bleed the traction/abs actuator and accumlator? i know how to bleed the brakes just dont know how to bleed the traction/abs actuator and accumlator. which ones should i do first, second, and last?
Old 04-20-05, 01:30 PM
lalaland
lalaland's Avatar
HTTP://WWW.PLANETSOARER.COM YOU SHOULD BE ABLE TO FIND STUFF THERE ON IT
Old 04-20-05, 02:52 PM
JTJerryls400
JTJerryls400's Avatar
1) ABS bleeding procedure is the same procedure used in
bleeding conventional brake system. On models without TRAC, if master
cylinder is rebuilt or reservoir is empty, bleed master cylinder
first. On models with TRAC, bleed TRAC system first. To bleed TRAC
system, go to step 3).
3) Connect vinyl hose to bleeder plug of accumulator. Loosen
accumulator bleeder plug. Start engine. Operate TRAC pump motor until
all air bubbles have been bled. Tighten bleeder plug to 74 INCH lbs.
(8.3 N.m). With engine running, add brake fluid. Turn engine off.
4) Connect vinyl tube to bleeder plug of TRAC actuator.
Loosen bleeder plug. Start engine. Operate TRAC pump motor until all
air bubbles have been bled. Tighten bleeder plug to 74 INCH lbs. (8.3
N.m). With engine running, add brake fluid. Turn engine off. Clear any
code(s) stored. See CLEARING CODES under DIAGNOSIS & TESTING.
but I have problem with (3) - there is no fluid at all, not pressurized air too... strange but trac work and abs too, (4) was fine as instruction says.
let me know what happen with (3) when you will bleeding yout trac system
Jerry
Old 04-20-05, 04:25 PM
SCV8
SCV8's Avatar
I have been using a hand operated vacum pump, with a resevoir for the fluid, no pumping, or yelling required.
Old 04-20-05, 05:35 PM
/Aerostar\
/Aerostar\'s Avatar
That so much fun though. I must have yelled "push" and "let go" about 50 times each
Old 04-22-05, 05:25 PM
inovashn
inovashn's Avatar
if you don't bleed the abs part, is it possible for the brakes to actually lock up?????
Old 04-26-05, 07:34 PM
inovashn
inovashn's Avatar
no replies?????
Old 05-21-05, 05:09 PM
blaznsc4
blaznsc4's Avatar
Jerry
where would this accumulator be? what does it look like? can someone take a pic of it to show me where is this located so that i can bleed the motor? also how would i operate trac pump motor? is it when the trac light comes on or off? i know how to bleed brakes its just that i dont know how to bleed the trac pump
Old 09-02-05, 07:42 AM
poser714
poser714's Avatar
Im bring the thread back from the dead. I also would like some more info or pics on the bleeding process. i have already bled my brakes but they still feel soft the first intial press of the brakes, if i pump the brake pedel first and the press again the brakes feel great i just would like to know how to bleed the abs system or atleast tell me where exactly the bleed valve on the system is. I plan on doing the TT brake set up eventually but i would like to have more sensative brakes for the time being. I havent done this yet but I heard that i might need to leave the car "ON" but not running, but in ignition, so that the abs system can build pressure or something like that then bleed the brakes again. well any info woudl be great.. thanks
Old 09-02-05, 07:44 AM
poser714
poser714's Avatar
oh BTW i dont have TRAC if that helps.
pishta
Suspension and Brakes
05-09-19 07:20 AM
kpielmeier
11-17-18 06:51 PM
JTJerryls400
17
04-18-17 03:37 PM
98SBF
11-13-08 09:28 PM
Lexs400
Maintenance
05-30-04 12:48 PM
Quick Reply: bleeding brakes?
