Brake LS 400 Upgrade questions
I saw someone who was selling a larger Brake caliper at one of the forums. The Brakes were a upgrade for the SC 400. They were black calipers that said LEXUS on the outside. They said they we LS 400 Brakes.. Anyone know anything about this Mod ? I have a SC 400 1997. Will they mount on the same Bracket ?
try using the search function. i know your knew but there is like at least 10 post on this already. and yes the ls 400 brake upgrade works
you will need ls400 calipers and rotors, you cannot use your sc rotors with ls calipers
ls400 calipers and rotors serve as a direct bolt-on.. the only thing you will need to modify if your dust shield because you are putting a bigger rotor on
Originally Posted by jgscott
Hey thanks for your help. This was what i was trying to find out. Do you know what to do to Mod the dust shield, bend, cut ? Or can you also mount the IS dust shield ? Thanks
