GS430 L-Tuned Suspension Install
#63
Last night I had to follow my wife (who was driving my car since her window was stuck down) and as a result I got to see my car from a distance, on the road.
Wow I have to say I love how these L Tuned springs make the car look. The stance is perfect and the overall effect is just great. So to anyone up for a mod I fully recommend these springs!
#64
Please Help
Today after replacing my suspension, I found an upper control arm, rear sway, 2 bump stops, tie rods, and ball joints that all needed/need to be replaced. Futhermore, all l-tuned shocks were shot.
#65
#67
Just wanted to say thanks to the extremely helpful write up on the suspension install. I followed jonathancl's advice to the "T" and everything went extremely smooth. Excellent write up and thanks for taking the time to add all the pix too! A+
~Da G
~Da G
#68
Hey guys, the GS300 and GS400/430 install is the same right?
Also, I have air tools and impact wrenches. Is it ok to use these to remove the suspension. I know installing it I will need to do it by hand with the torque wrench(torque to proper spec), but for removing is ok to use a impact wrench or is that too much power? Breaker bar vs impact wrench. It's a lot of effort saved
#69
#70
...but for removing is ok to use a impact wrench or is that too much power? Breaker bar vs impact wrench. It's a lot of effort saved
#71
Originally Posted by jonathancl
Breaker bars are safer. 2.5-3 feet is plenty to give lots of leverage and control.
Impact wrench is probably a better choice overall in this situation.
#72
Originally Posted by DoubleWhoosh
On jackstands, it could be more dangerous, as you might knock the car over.
#73
Man, I love this thread. I've read it at least 5 times. I just wish I had the guts to tackle this myself. I'm definitely a do-it-yourselfer, but this is way out of my league.
#74
Yes...This is a GREAT thread, I used it as a guide to install my Tein CS.
My 2cents tip to those DIY guys out there thinking about tackling this....Treat those ABS sensors / lines like trip wires to explosives, or else you will find yourself forking out unecessary money to repair a faulty ABS sensor.
#75
i kno this is an old thread but how did u guys get to the top of ur strut mounts in the rear???? did u have to take out ur back seats or decklid.. etc...... thanks... i'm installing my tein cs tomorrow...
