? for GS owners with Tein CS...
Old 04-26-05 | 07:57 AM
JacobT's Avatar
JacobT
Default ? for GS owners with Tein CS...
What's the best setting for Tein CS both front and rear? I don't have EDFC so I want to pre-set it at the installation and leave it along. I don't mind stiffness and I want more sporty than comfy. I was thinking 4 clicks for both front and rear, what do you think?
Thanks.
Old 04-26-05 | 08:34 AM
KevinGS's Avatar
KevinGS
Thanks.
No real "optimal" setting, except something in the middle. You'll probably want to set it for around 4 or 5, for stiffness and control purposes. If you live where the roads are smooth, then you may even opt for a 2 or 3 setting.
If your roads are bad, then maybe around 7 or 8, for optimal comfort/handling purposes.
I change mine quite often with the EDFC depending on mood/road surface/weather condition/location.
Old 04-26-05 | 09:31 AM
TYPEII's Avatar
TYPEII
Even on "0" the ride is not even rough at all, I am rollin on 20" and it doesn't even compare to a Mazda RX-7 with the R1 package.
Old 04-26-05 | 09:59 AM
JacobT's Avatar
JacobT
Thanks for the replies. I think i will set it to "0" to begin with. How about the ride height? If I want about 1 finger gap all around, how many threads from the bottom should I adjust the rings to?
Old 04-26-05 | 10:26 AM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
yeah i agree, if you don't mind stiffer ride for better handling, get it on 0 and 0, good handling. or if you want, 0 front and 2 in the back. abit softer back is better for handling
Old 04-26-05 | 10:31 AM
TYPEII's Avatar
TYPEII
It will depend on what wheel and tire size U are rollin on.
Old 04-26-05 | 12:55 PM
JacobT's Avatar
JacobT
i have 20's which are 1" taller than stock.
t3ts
09-02-06 01:04 AM
chuckb
Suspension and Brakes
28
11-03-05 08:25 AM
HKGS300
03-04-05 02:16 PM
rominl
07-13-02 05:09 AM
minh
05-04-02 03:20 AM
