LS Brakes= to TT brakes?
Old 05-02-05, 11:26 PM
rominl
exclusive matchup
rominl's Avatar
Originally Posted by LEXISM
right now i can put my finger in between the stock caliper and the rim spoke.... how much clearence would i need?
umm.... one finger? that's like 12mm, i doubt it...
Old 05-02-05, 11:27 PM
rominl
exclusive matchup
rominl's Avatar
Originally Posted by RMMGS4
Yup, they are LS400 rotors.
I test fitted TT rotors, but they were slightly too big.
Not sure were he ordered them from. I'll try to reach im. He's not on the forums lately cause he's trying to graduate soon.
ah so it's just a tad smaller than 12.7" i guess. if memory serves me right the supra ones are 12.7"?
Old 05-03-05, 09:26 AM
LEXISM
LEXISM's Avatar
so 12 mm would not be enough?
Old 05-03-05, 12:32 PM
bluelex
bluelex's Avatar
whats your wheel offset?, you might be able to run a small spacer to get it to fit..
Old 05-03-05, 01:02 PM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Just PM me your e-mail addy and I will send you a pdf file of the TT brake template.
Not sure if you are going TT or LS, but I can ask Jawnthen what the clearance was compared to the TT.
That is whenever I can get a hold of him.
Old 05-03-05, 01:50 PM
rominl
exclusive matchup
rominl's Avatar
well it's just a wild guess. if anything you just need a pretty small spacer i think
Old 05-03-05, 04:33 PM
jawnthen
jawnthen's Avatar
Okay RMMGS4 convinced me to log in for a bit and respond....didn't know these brakes have become such a hot topic of late. Don't have much time to discuss but I'll post some pics that ya'll haven't seen before.
Here's a pic of the bolt that was shaved off.
Old 05-03-05, 04:36 PM
jawnthen
jawnthen's Avatar
also heard about a mystery bracket for these brakes. Here's a profile shot of my setup using no brackets. If someone had brakcets made then I would assume that the placement of the caliper with respect to the rotor would be different.
This is the best shot I could take for now...didn't want to take the car out of the garage otherwise I might be tempted to clean the car, and I just don't have time for that anymore.
Old 05-03-05, 04:40 PM
jawnthen
jawnthen's Avatar
Default a little info before I go
The rotors I got from irotors.com
My wheels are 20x8.5 with 38 offset. No spacers needed to clear the brakes.
Old 05-03-05, 05:18 PM
LEXISM
LEXISM's Avatar
Thank you very much for logging on ......
in that pic which bolt is shaved off?
and the rotors you bought from Irotors are what size?
my email is emanriquez@southlandcu.org...Thanks guys
my rims are 20X8.5 w/ a 35 offset
Old 05-03-05, 08:27 PM
RMMGS4
RMMGS4's Avatar
He ordered LS400 rotors from i-rotors.com
The nut you see with the cotter pin is shaved. You can't see the shaved part from the angle of the photo, but it's pretty much the part you don't see is what's shaved. This was an old pic he dug up. One of these days he'll have to take the wheel off and show the right angle. Till then thats all he has.
Check your e-mail for the TT template. Jawnthen said if the TT clears then the LS will clear for sure.
Sounds like your real close.
Old 05-03-05, 11:52 PM
rominl
exclusive matchup
rominl's Avatar
thanks for teh info, jon. but as far as i know no one is making brackets for the ls400 brakes. i think someone is making brackets for the ls430 calipers though
Old 05-04-05, 09:01 AM
johnee78
johnee78's Avatar
Your correct..The bracket isn't for the caliper because the caliper is a direct bolt on..The bracket is for clearance of the caliper from the bolt..Just thought I should clear that up..
Old 05-04-05, 09:10 AM
LEXISM
LEXISM's Avatar
do these rotors have zinc plating ? Irotors offers it
Old 05-04-05, 12:29 PM
RMMGS4
RMMGS4's Avatar
I think it's cad plated from irotors. All the rotors I've bought were cad plated.
Quick Reply: LS Brakes= to TT brakes?
