LS Brakes= to TT brakes?
#31
Northern California Regional Officer
Originally Posted by johnee78
Your correct..The bracket isn't for the caliper because the caliper is a direct bolt on..The bracket is for clearance of the caliper from the bolt..Just thought I should clear that up..
Thanks for the clarification.
So where does this mystery bracket go?
I hear about it,but I haven't seen anyone show a picture of it, where to get it or what it actually does.
#35
This bracket mounts between the steering knuckle and the lower balljoint..When it is installed it raises the hub and allows the clearance needed for the LS400 caliper..This bracket will also lower the vehicle about .50.. I will post some pics of the actual bracket installed..
