LS Brakes= to TT brakes?
Just wondering what is needed to do this mod? what exactly needs to be modded? and is it just as good as the TT brake set up? whats the difference between this and the GS4 brakes ?... I can possibly get some for under $300
Mods can you leave this for a bit...thanks
These brakes will offer similar braking power to the TT supra set-up..In order for these to fit on your GS you will need a bracket that allows clearance..Other than the bracket it is a direct bolt on..
as for the ls430 calipers, you need new brackets made for sure, they don't even bolt up
i remember rmmgs4 posting pics about it, you can try to search. it's around last yr sept time frame
but personally i wouldn't do it. you are playing with suspension bolts... sounds scary enught to me. that's just me of course
Northern California Regional Officer
Originally Posted by LEXISM
any pics of jawnthens ride? so you ned to shave the bolt down but not complettely off ...just enough so that it clears right?...any pics
I never took a pic of the shaved nut..
Basically all it is, is a tie rod bolt that holds the ball joint to the steering linkage.
You have to cut a 45 degree slice along one edge of the bolt using a dremel with a kevlar blade. This nut is also held in place by a cotter pin, so it's not going to come loose by any means. In fact even with the bolt removed the linkage will not come apart without using a ball joint removal fork and a 5 pound hammer to separate the two pieces. Based on that knowledge, Jawnthen made the call to let me put his nuts under the knife . (Pun intended)
That said, I take no liability if someone tries this at home. Do so at your own risk.
Originally Posted by RMMGS4
Man I just posted a pic of Jawnthens LS brakes today here: https://www.clublexus.com/forums/sho...d.php?t=160739
I never took a pic of the shaved bolt.
You have to cut a 45 degree slice along one edge of the bolt using a dremel with a kevlar blade. This bolt is also held in by a cotter pin so it's not going to come loose by any means. In fact even with the bolt removed the linkage will not come apart without using a ball joint removal fork and a 5 pound hammer to separate the two pieces. Based on that knowledge, Jawnthen made the call to let me put his nuts under the knife . (Pun intended)
Originally Posted by rominl
hahaha that's so funny glen about the last sentence. it's very true though, if you know what you are doing, it's probably all good, otherwise, you take you rown risk
Yeah Henry that's a good point.
I was about to mention about using a fork and the 5 pound hammer to separate his ball joint, but I thought I better not.
Oops, I guess I just did.
wowo thats one nice caliper?
what kind a rotors is he using? and would this clear my rims ?
the claipers are big, your wheels need to be able to clear bbk
i really forgot the rotor size already, i think it's 13"? or maybe they are just the normal ls400 rotors?
I test fitted TT rotors, but they were slightly too big.
Not sure were he ordered them from. I'll try to reach im. He's not on the forums lately cause he's trying to graduate soon.
