drift SC
#46
Originally Posted by gadgetSC
B6 is correct
Soarer_25GTT .......The Hipermax II's ride great for normal driving. I had mine at the softest setting and it was very near stock as compared to riding in my 2kSC.
I have the Zeals on the same car on the first setting and it feels the same as the stock 2k.
sc.Fred.....I dont know which one is better the RIGID or PILLOW BALL mounts. If you need more adjustibility you might want the pillow ball. My HKS were ridgid also and were fine for me.
gadgetSC-t
gadgetSC-t
#47
The 6 way adjustability is referring to the dampening. The best part is that there are no allen wrenches required to make adjustments.
There is a small **** ontop of each coilover with the six positions clearly marked to make adjustments.
You'll be quite satisfied with the build quality. I think they are worth every penny
gadgetSC-t
gadgetSC-t
#48
this is what is going on my 300. we use aragosta dampers and swift springs. both the dampening and the spring rates are totally custom to order though we do have 3 ideal setups for street, drag and circuit.
for those of you that are looking to replace your coilover springs, i highly reccomend Swift springs. I have driven on just about every JDM spring and swift is by far the best. (they use them for JGTC)
#50
Originally Posted by Soarer_25GTT
Roo, do you have any more info on the Swift springs? Do they only do coilover-specific springs or do they do normal lowering springs too?
#51
all you drifting guys might want to check out what im selling...i have a set of drifting teins....full coilovers for a good price...
Jeff
https://www.clublexus.com/forums/sho...47#post1457547
Jeff
#52
#53
the teins im selling are 16 kg front and 10 kg rear and are 16 way adjustable with a **** on top of the strut and there only $900
sorry for the sales pitch...but for a drifter there awesome...type HE drift spec...winding master!!!
have fun
Jeff
have fun
Jeff
#55
welded and D2 coilovers
WELDED DIFF FOR $50 FTW. if u do weld the diff. make sure you weld a solid ball of metal in it, LOL. the weld broke 2 times, its not fun taking the diff in and out. i support the welded diff because im from the land of the cheap (nissan community).
#56
#57
I would not recommend welding the diff in any situation. I've seen welded diff's lock at high speeds and throw cars into anything near by. Not a good time at all. If you want to drift for cheap, then get a diff out of a turbo MKIV supra. They are TRD 4 pin LSD units and work perfectly. I am land of the cheap, but also land of the smart. I used a cheap cusco 1way diff in my 180sx (240sx) and it cost me $100.
#58
and sounds to me u live in japan. used stuff are often cheap over there. us = no used cheap stuff = NEW products are the only thing i can get, if they even have it.
#59
third gear, 5k rpm, feint and clutch kick = no understeer.
#60
Easiest way to combat understeer is get some great front tires (i recommend Potenza Re-01r's) enter with more speed, give yourself a few ticks of negative front camber, (I use -.02) or just do what I did with my soarer...Big turbo, plenty of speed and keep that throttle down. Dont try that last one if youre new to slidding lol
