Will stock Supra springs lower the SC400?
I did a search and couldn't find this info.
It appears that the spring rate is stiffer, but will the ride height be lower with stock Supra springs/struts?
Thanks!
Thanks!
so if you went with the tt shocks and aftermarket springs wouldnt it come out to be 1.4 drop then?i was wondering if a set up of tt shocks/springs in back for a .7 drop and stock sc shocks with eibachs in front... how would that ride?
With that .7 drop in height do you suffer any ride comfort? Picking up a 98sc300 on friday and I would like to get rid of that jacked up look without the loss of ride comfort.
However you are getting ...or already got a 98 SC so most of those used setups will probably be older and degraded so the quality level may be effected moreso than someone with say a 93 SC. And keep this in mind if you go looking for Supra parts. Supra owners are harder on their cars and thus the wear may be even worse.
I have aftermarket Supra suspension myself and the added drop and handling it gives is more than worth any amount of comfort i sacrifice (wich is minimal) . But thats my preference.
By your post , i wouldnt go with any Supra suspension . Theres plenty of springs out there made for an SC that give a modest drop, and you give up almost no comfort. and if you can swing it get some coilovers and you can play around with the settings til it feels right to you.
Hey CantSeeMe,
I was wondering if you might allow us to "see" what your car looks like with your suspension set up, got pix?
93 Black SC300 --- Supra HKS springs w/KYB agx shocks- Daizun front LCA bushings (both upper and lower)- Supra TT sways- TT chrome wheels- Aliga LS brake calipers-
