front suspension vibrates
you said you've replaced most everything. Have you replaced the lower ball joints? Your symptoms are exactly the same that I just remedied by changing them out.
thats what i suspect, is ball joints from what i have been reading in the different threads. was it covered under warranty , if not how much was parts ? thanx for the input on this guys
Originally Posted by HKS_GS430
i hate this vibration, sometimes it feels like wheel is going to pop off. only at 65-70 mph, i can either drive a lil slow on the highway or a lil fast cant even go the speed limit,,gosh
Originally Posted by STONER
I just fixed this exact problem with my 01 430 today. Had a vibration between 60-67 or so. I bought the car a couple of weeks ago, and when I had it checked, the guy told me that the lower ball joints were shot. I got the parts from Darrell at Sewell Lexus, and installed them today following the DIY I found on this forum. Drove her all the way home at 63 just because I could do it without the VIB. I can't promise that this is your problem, but I would bet that's what it is. BTW the hardest part of the install is getting the bolts off. I go tomorrow for the road force balance, and a four wheel alignment.
Anybody have the exact torque for the bolts in this project?
Good Luck
-Andy
Good Luck
-Andy
Originally Posted by jroosh
How many miles on your '01 when the problem became evident?
Originally Posted by tmasta
how much are the lower ball mounts? and the bushings? i did the road force and it still vibrates... not as bad but still some.. pretty annoying.
Here are a couple of threads
https://www.clublexus.com/forums/sho...+joint+replace
I wish
Just spent $1500 to fix this, and no improvement!!!!
Last week - repaired bent rim and had wheels balanced.
Today I had the lower ball joints done, outer tie rods, new rotors (all OEM), brake pads, alignment.
Wheel still shakes like the devil 55-65. I'm pissed.
My mechanic wants to try "hub bearings" - whatever those are. I may try having the wheels balanced again - I have no idea where I can get road force balancing, though.
I don't know - the shop manual states other causes for steering wheel shimmy include worn shocks, and steering rack problems. I hope it's not the latter, though how to even tell!!?
remount wheels trqing in a star pattern
check for play in lower control arm bushings
Originally Posted by lexforlife
how much air in your tires i run 40lbs front to keep tire from running on inner tread and chopping up the tire
I'm having my control arms done and my sway bar bushings while i'm at it.
Originally Posted by rominl
a lot of potential cause
1) steering wheel presentioner
2) worn bushings
3) wheels not balanced well
for me 1 was the cuase. and now 2 is my cause. for 3, it's till possible, unless the shop knows what they are doing and have the right equipment. i attended some lecture this past weekend on alignment and wheels, and i learned about how a wheels could be balanced all perfect on spec and computer, but you still feel the vibration
2) worn bushings
wasnt the steering wheel pretensioner problem only on 01+?
I have a 98. Where is this pretensioner and how to tighten?
I know the earlier models (98-?) had a bad rack design that was revised and replaced for free by many dealers. My tech at Lexus told me about it and Rominl had his swapped free via dealer.
