Anyone use Tein SS??
Hey guys anyone use Tein SS here? Had it on my TL and it worked great! Everyone here seems to use the Tein CS which is another $300-500 more or so. Not sure if its worth it. Definately will get EDFC as well. Any inputs is appreciated.
ben
ben
Originally Posted by benzo555
really? didn't seem bad at all on the TL at all. Apexi was much harsher than the teins on full hard.
I talked to Tein and the SS are exclusively available only in the US. I could not find the specs on HA's so I could not compare the two together. They assured me that the SS is more streetable coilover than the HA's. The HA's were discontinued due to low sales. Got it on order from Carson.. Ill let you guys know the outcome!
I think SS must stand for SUPER STIFF.
The spring rate is a lot stiffer, compared to the Flex and the CS , which are the two most popular Teins.
Model---F/R Spring rate
CS-------500/450 lbs Near or better (some say) than stock.
Flex------560/500 lbs Firm, but streetable, BMW like.
SS-------780/670 lbs You be the Judge.
PS - Henry has no life.
PS - Henry has no life.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Carson Toyota are awesome to deal with.. Unfortunately the DSR strut bar is discontinued
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
The One
We have to be a little careful when comparing spring rates. The way the shocks part of the coiloer is setup is just as important, if not more. Remember that the EDFC adjusts the valving on the shocks, not of the springs, to control ride properties. The springs come into play more in terms of handing. You can see this in the comparison of the Flex and CS. The spring rates are pretty close (in comparison with other Tein springs) but the ride properties are different.
Still, since Tein does not have shocs "specs", we can only glean their intentions by looking at the spring rates. When comparing spring rates, it also depends on the car since each car has a different drive properties and weight.
The numbers for the CS for example:
GS: 504/448
IS: 559/448
LS: 336/224
SC: 559/336
Tein tunes the coilovers to some goal for specific cars and depending on what the stock rates are, the ride may be close or drastically different.
GS: 504/448
IS: 559/448
LS: 336/224
SC: 559/336
