help with brake noise
I have a problem with my front left brake. When I press on the pedal I hear a squeak come from that side of the car. It is quite audible. This is when the car is stopped. When I am driving and have the windows down I dont hear it but this is probably due to the engine and other noises. It also only squeaks when the pedal is pushed past a certain point, as if you were increasing the pressure on the pedal. The more I push the louder it gets. Any ideas on what this is before I take it to the dealer?
Rich
Rich
Master Thread Closer!!
Check the brake pads....the noise maybe the calipers digging into the rotors.
On the other hand, it could be just rock pebbles/dirt between the pad and rotors.
I'd suggest removing the pad and clean them if its still looks good....then apply a some anti-squeal paste before re-installing.
Good luck.
Pete
Good luck.
Pete
Thanks Pete I will try that. I hope it isnt anything bigger than that. I dont notice any grooves or anything on the rotor and the stopping power isnt getting any worse.
Usually a run of the bed in process would solve the issue.
