Rotor Removal
Old 07-02-05, 02:54 PM
beaterKU
beaterKU's Avatar
Default Rotor Removal
So, I was going to put on my new Brembo rotors today. I started on the left rear. Got the caliper off and started in on the rotor. This sucker is on there good. I cleaned up all of the rust/corrosion around the barrel and still nothing. The service manual shows that it is just held on but the wheel itself. Am I missing somthing here? Let me know.
-Nick
Old 07-02-05, 03:42 PM
Mr GS400
Mr GS400's Avatar
-Nick
You'll notice a couple of threaded holes in the rotor pretty close to where the lug nut studs poke through. I don't recall the size of the bolt you need but you simply wrench them in alternating from side to side forcing the rotor out.
The rotor will break loose. It's just seated tight from age and rust.
I hope this is clear enough and helps.
Good luck!
Old 07-02-05, 06:35 PM
PHML
Master Thread Closer!!
PHML's Avatar
yah...get either 12mm or 14mm bolt or something like that....if forget the exact size....and screw that into one of the holes on the rotor hat....it should "pop" the rotor free from the hub.
Good luck.
Pete
Old 07-05-05, 08:44 AM
jonathancl
jonathancl's Avatar
7mm bolt with 1.0 pitch threads.
From this thread.
Old 07-05-05, 09:11 AM
CinFulxgs
CinFulxgs's Avatar
Good info...
This site RULES.
Old 07-05-05, 10:42 AM
lexforlife
lexforlife's Avatar
or use a rubber mallet and tap all the way around it will pop off i use this method for the aftermarket rotors dont come with those holes
Old 01-11-07, 10:21 AM
kimsinger
kimsinger's Avatar
Great info (about the two threaded holes). I had removed the calipers without a problem but was stumped how to get the old rotors off until I checked out this site. Found a couple of bolts in an old jar - screwed them into the holes in the rotor - and it popped off clean as a whistle. Thanks a lot!
Old 01-11-07, 04:17 PM
jonathancl
jonathancl's Avatar
I saw this thread and was planning to remind people to 'use search'.
And you did.
sbrown329
09-22-18 02:36 PM
InfamousLS
09-27-13 06:17 PM
Reesetrict
Suspension and Brakes
27
07-24-12 10:49 AM
Och
09-10-11 07:06 PM
VJZ
04-09-09 10:34 PM
Quick Reply: Rotor Removal
