Told I need new struts, need help to know what this means
I have a stock 99 sc400 with 82k miles on it. When I took it in for its 75k check up at 79k, the Lexus rep at Lexus of Rockville Centre told me I needed new struts, and that that is the reason I hear a squeak come from the back end of the car when I get in or out or take something mildly heavy ot of the trunk. The problem is, I have no idea what this means. I am not looking to do anything fancy as I only anticipate having the car another year or so, but want to make sure I don't let an opportunty pass me by. Can someone explain in simplistic terms what it is that Lexus is suggesting I do?
Thanks
Thanks
Thanks
Thanks
you need new shocks basically. i had kyb gr2's and they worked well as a replacement for the oem ones. now using kyb agx adjustables but that will cost a bit more brand new. good luck.
It is unlikely the squeak is from your struts (shocks).
Do a bounce test on the rear of your car to test what condition your struts are in.
I would lay you odds it is not your shocks, unless you carry a lot of heavy stuff in your trunk all the time, your shocks should last a lot longer than 80k miles.
I would inspect all rear suspension components for loose nut or bolt and spray a little silicone lube into the upper insulators of your shocks and see if it solves your problem.
Rob
Rob
thanks for the help guys
car passes the bounce test, but it does squeek when i bounce it. I will have him look at the rear bushing and check the suspension nuts and such. the only time I have anything heavy in my trnk is winter, when i carry 3 cinder blocks, which really isn't that heavy.
