So my air ride is done
#32
i got this one from ebay... 4 gallon.... it's kinda expensive considering its capacity....
The only thing that sucks about it is that it's not like a spare tire in which you can "bolt-in" like a spare tire. I had to make a little bracket to keep it down in the spare tire well. In fact... I placed it off-center so i can mount my 2 compressors next to it. So all of my components are hidden.
#34
haha... my trunk looks like a disaster... air lines and misc wires ALL OVER the place. I think the only way to make my particular setup look clean is to hard line everything (something i'm considering in the future if i ever want to "show" my setup). This is why i built a false floor to hide everything.
As far as making a kit... still a possibility.... but kinda hard at this point since there are only a select few that would be interested.
#36
my valves\
gauges in glovebox
my top secret setup
how close i get when i'm going down (not all the way down yet)
sittin on the sideskirt
i love takin shots like this
my driveway is a t pretty mean cuve which is why it looks high in the back
messin around... i got the left up and right down (i like clowning on trucks like this cuz most trucks can't go side to side as much as my car can)
and i've got a few other pics under my name in the gallery
gauges in glovebox
my top secret setup
#37
Originally Posted by ummagawd
I've got complete adjustability. Ride height (obviously), but on top of that... I decide my max drop (air all out), dampening, and overall stiffness.
I use the air PSI to determine how stiff/soft i want it.... and then fine tune with the dampening adjustibility. Then finally adjust at what ride height I want this particular setup to ride at.
#39
Originally Posted by ajhaley
Could you describe this better? You can adjust the ride height by the amount of air I assume? You also adjust how you want the ride by the amount of pressure? Is that at any ride height or the more air, the higher, the stiffer? I can't visualize it too well even after looking at the picture of the bag where the spring used to be.
so say for instance my ideal PSI is 90 in the front.... but i feel that it sits too low.... i can raise it up via the coilover perches... get it? I can also make it so that "all out" (fully dumped) leaves a 2 inch gap between fender or tire.
#40
my trunk is also messy from teh air ride stuff and iw as redoing mysystem but never finished.
for those that want to try to attempt custom air suspension go to www.vipstylecars.com and visit the suspension section a few of those guys over there done the same thing.
You car looks good ummagawd.
ive recently put a forsale sign on my car.
#43
*sigh*... i hate to be the reason to sell... say it ain't sooooo! you've got a wayyyy nicer car than mine (btw... do you have pics of your interior?)
