Diy **Air Runner** air suspension questions
Has anyone installed themselves ??
possible trigger pulling ..
but what do know if anyone here has done it
I read most of Jon's post on the install
The airrunner pretty much bolts up to the stock locations right? I had airride and the shop had to fabricate some upper mounts for the kit.
It should be pretty straight forward, are you going to tackle this yourself?
It should be a very straight forward install. I'm not familiar with the parts of the air runner kit but have installed many other air suspensions in the past. If it's a true kit, it should bolt straight up to the stock shock locations. It's just a matter of running air lines and some electrical...
Originally Posted by GTFM
the air lines are the part that bother me
can i run these lines like the EDFC lines for Teins?
It's actually pretty simple...it's just as easy as running power wire for a stereo. You just have to be careful of sharp edges and kinks in the line. Other than that you can run it straight through the fire wall and under the carpet.
On another note, have you heard of what the ride quality is with the air runner setup? The picture above has intrigued me and I may be willing to part with my Tein setup in favor of ease of adjustability.
i got a great price on this thanks to a friend
proabably going to order on Monday
anyone need coilovers
Originally Posted by sputniknyc
definately pimp!
What are the pros/cons to this setup?
one con i think of is air leaks
but the rest is all pros
it handles like a stock LS430 or so i have been told
i dont plan on going to the track and never would
another reason for me getting this is trying to not mess up my new bodykit coming in
plus the COOOOOL factor
