supra tt brakes
im about to do a supra tt brake conversion on my sc300 and i was wondering if anybody had any tips before i do the conversion that would help me before i do it
remove the dustshield or you will have clearance issues....also make sure before you install the calipers that your wheels will clear without rubbing or you may need spacers.
1. Make sure you have rims that clear. Make sure you have Hi- Disc rims or you can measure to see what fits.
2. I would recommend you purchase a supra spare tire , as your stock donut or full size will not fit, in the event of an emergency.
3. Make sure the brakes have all the parts included ex: rotors, caliper pins, Supra TT caliper bolts or shorter bolts as your stock bolts are too long and may hit the rotor.
4. removing the heat shield is key also, as it gets in your way of the installation.
Nosexnolex
Wheels, Tires & Brakes Forum
01-03-08 06:26 AM
TexasGS
09-13-06 05:55 PM
