Spacer with lug extender?
i believe they are the custom spacers done by tm engineering themselves directly. you can email todd@tmengineering.net about it
the ride is perfect. the car is lowered and i drove it and it was awesome. no vibration no nothing
i posted in te gallery are under my name a pic of the side of the car where u can see how the 20mm spacer in the rear and 15mm in the front to clear the brakes would look like
https://www.clublexus.com/gallery/data/500/P9080070.jpg
https://www.clublexus.com/gallery/data/500/P9080068.jpg
Originally Posted by Adam2562
i posted in te gallery are under myname a pic of te sideof the car where u can see how the 200mm spacer in the rer and 15mm inthe front to clear the brakes would look like
Adam2562, can you tell me what i need again for the front either spacer or spacer with studs to clear my Supra TT? What does the installation involve? Do the front brakes and rotors have to come off? How easy was the install in the front? I know we had talked about this but i forgot what was needed to do this? I just want to do this the safe way
I beleive you have the Supra brakes also in the front... You can PM me if you want or write back to this thread.... Thanks again
Tony
Tony
Originally Posted by STONER
tony - you getting spacers for the donz?
Tony
no pull the wheel off and pull the caliper and rotor off then hammer out the original studs and replce it with the new ones.. but u need to force them in place .. i used an extra lug nut and torque it in by using an impact gun... its a job u need a shop for.. unless u have good tools at home.. like an air gun.. or strong portable impact... then put the rotor back on then ur caliper then...then put the spacer on.. ur set... better if u have a lift to lift up the car so ur at eye level with it.. andsorry it was 20mm not 200mm lol
This is very very important!!!
Originally Posted by GeorgeGS4
wow that does look a lot better thanks for that... what spacers are on that thing? and hows the ride quality?
btw, nice conversion van with rims in the second pic
The van, yeah that's our pickup/delivery shop van! 02 Astro cargo with 20" custom painted L-Sportline Model 4's and 245/275 Michelin Pilot Sport A/S's Also lowered a little over 4" - what a pain that suspension was and still in progress!!!
Originally Posted by rominl
just take off the wheel, put on the 15mm adapter and put back the wheel on
Tony
