Daizen GS front control arm bushings - review thread (final)
#167
Master Thread Closer!!
wow....breaking chisel left and right....why not just burn it out with a blow torch.
Btw...seems like a DIY job if you got the right tools, downtime, patience, and guts to try. The LS400 writeup made it sound tempting to DIY....comments?
Anyone got any ideas how hard/easy to install the new bushings without a press?
Thanks!!
Thanks!!
#168
burning takes much much longer than pressing, if you have the right tool
and also, you need a very hot torch, coz' it's not that easy to just burn off those rubber in a reasonable amount of time. and even so, after you burn away the rubber, you still need to do some cutting
#171
i dont think its that much of a hassle. it is time consuming though just like anything else. for me, the trade of was worth it eventhough it took most of the day. like i stated above, if anyone wants me to get the bushings out and press the new ones in, pm me and ill do for you, for a fee of course.
#172
From the limited time I saw Todd working on it, I would say you better have a lot of time on your hands and have access to some professional tools. I consider myself a diy guy and I would never attempt it.
#173
its not hard by a long shot.. the castor arms each took me 45 mins or so to swap out
the lower control arms alittle more time more like 1-2 hrs each
the most important thing to have is a secure way to hold the arm and a good air chisel and patience
i used the weight of my car to hold in place and used liquid wrench and used 150psi air chisel in short spurts
dont give up guys , daizen and todd put loads of time into this and they work well
#174
The directions for the LS might give you DIY guys an idea. This is an updated link from his previous attempt: http://www.lexls.com/tutorials/suspe...aizenkit2.html
#175
Thanks!!
Thanks!!
That's why average mechanics won't do it, cuz it's not worth the time and labor for them to do it (eg, laziness). But the bushings are a drastic difference compared to the stock bushings and is the one component that can really make a BIG difference in the handling. Keep in mind, the weakest point in the control arm setup is the bushings. After 60K miles, the rubber is toast. Replacing them with the Daizen bushings makes the car feel like new again, and they will last a lot longer then stock rubber.
GS430lvr: It was nice to meet you that night! Glad you are enjoying your new suspension parts. Hope your family was OK hanging around all that time.
Brent
#176
Park Place lexus wants $1200 dollars @ 9.4 hours install time to install the Daizen bushings! Damn thats alot of money!!! ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Should I just bite the bullet and do it?
#177
BLiu: Likewise....always good to meet a fellow Lexus enthusiast. We didn't mind waiting around since we knew it was being done right! It sure is nice not to have that stupid vibration at 60mph. The car feels better than when I first bought it (at 30k mileage).
Delta: That is a lot of money! I'd shop around a bit.
-Scott
-Scott
#178
I called the place that installed my Torque Converter and asked if he knew of a place that he would recommend to have my bushings installed. He recommended NTB (National Tire & Battery) . So I called them up and they said they would do it for $95.00/ hr , but there would be no guarantee whatsoever on work. So that's around 900 dollars. I would rather pay the 1200 and have lexus back up the work and probably have better certified mechanics installing it don't you think?
#180
Originally Posted by rominl
and brent, so you got them on your car now as well?
Brent
