Daizen GS front control arm bushings - review thread (final)
#256
Originally Posted by engin_ear
This is great.
Do you hear any squeaking now or any other sounds coming from the suspension?
#257
Originally Posted by amwendwa
May be I should start a new thread, but what the heck. I've ordered my bushings, but don't have a mechanic I can trust. I'm the DC area. Is there a sticky on CL recommended mechanics and shops per region. Can't wait to get these babies on.
cheers
cheers
Let me find the thread.
It's post 236 in this thread. Jamiaca is the spot apparently.
#258
this is awesome Frank - thanks! I can't wait to make my appointment and get it done. I just have too much stuff going on right now, so I'm a few weeks away I think.
Jerry
Jerry
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#259
Originally Posted by nicola
So yea, def. best $450 I've spent so far (install + kit).
Frank, sucks about the kit - they told me you had problems but I thought it was resolved. I actually went in today to get it installed (they asked if you sent me lol). They mentioned your L-tuned shocks were leaking - both my fronts would not return to default positions without a bench vice so we tossed them. I'm real pissed, as I got them 7 months ago and they're already ****.
Yea I guess its time to get coilovers. The brake kit is getting returned and I'm getting a refund. I just have to figure out which comes first....coilovers...
#260
Let me just say I had these bushings installed by Todd at TM Engineering and That man earns every cent he charges to put them on. I'm very mechanically inclined and watching him work on my car I started having doubts if I could of done it my self. So many things are involve.
Thanks Todd
Solomon.
Thanks Todd
Solomon.
#261
Thanks Todd
Solomon.
Thanks Todd
Solomon.
#262
this is a question for todd
since doing the upper arms the other day i am having a small problem with alignment , i have a slight drift/pull to the right my tires are not that great i dont know if if because now everything is firmed up front that the tires have worn to the old bushings and now they wanna pull
#266
Originally Posted by lexforlife
i am hoping todd will chime in here about my slight drift/pull to the left since doing lower bushings and now the uppers and i had the car aligned twice since
Just a thought.
#268
Ok someone told me to post up here sorry all been out sick for as long as I can remember at this point! Ed you should switch your front tires left to right to see what happens. Only will take a few minutes and that should help a lot to see at the very least what the problem ISN'T
Could be radial pull from one of the tires.
As far as anything else, it would have to be the alignment, unless something else shifted on the crossmember or even one of the crossmembers themselves.
#269
Originally Posted by DoubleWhoosh
Ok someone told me to post up here, Ed you should switch your front tires left to right to see what happens. Only will take a few minutes and that should help a lot to see at the very least what the problem ISN'T
okay thanks todd for replying
i did flip the tires , had alignment redone after finishing the upper a arms and toe was way out camber came back to within a tick of spec , pulling not quite as bad but still tends to drift when you say cross member are you suggesting the engine cradle area may have moved and if so how do i twist back into place
#270
This will tell you if it's the tires. Then we can go from there. Tires can go bad at any time, even brand new ones.
