Installed tokico blues/espelir/daizen front camber kit
Finally installed them today, fronts were simple just took the long control arm bolt out and the shock came right out. Rears were just as easy, removed the caliper, undid the upper swaybar link, shock bolt, had someone step on the hub, and came right out. Drop is pretty low but the ride is just like stock. Perfect!! It's dark right now so I can't take any pictures, but will take some in the morning and post them up.
Didn't get to wash it, but here are a few pics. Ride is great just like stock, but is rubbing alot. Hopefully that'll all change when I put the rims on.
Before:
after:
Before:
after:
Nice job! The car looks great! I'm just about to order the Enkei LX-M's 18x8.5 all the way around. I was thinking about the same suspension set-up also. Did you get the Tokico Blues?
By the way, is the camber kit necessary? Or will I be fine with the new suspension?
Originally Posted by got_trd
looking good.... now if only you would take it out to the meets
