Vibration
Vibration
Hey guys,
My car has been vibrating while going around 70 + mph. Do you have any idea what it may be? I'm concerned and I hope it isn't too serious. any ideas?
I would definitely try to balance first as xknowonex mentioned. If that doesn't fix the vibrations, try to take your car to a wheel shop and have them spin your wheels on the balancing machine to check if they are "out of round" or slightly dented. That will cause vibration when you exceed speeds of 70mph. I am currently buying new wheels for my SC300 because the wheels are "out of round" and cause vibrations. It sucks because that's an expensive fix. Good luck and hopefully it just needs balancing!
-Harpreet
-Harpreet
There are a few things that it could be:
1) Wheel Balance
2) Bad tires (uneven wear, or toe in)
3) Wheel Bearings
4) Tie Rod Ends
5) Bushing on top of front struts (I kid you not, my car was vibrating and this was the problem)
6) Controll arm bushings
The list goes on... I suggest you take it to a shop and have them go through the suspension top to bottom...
Also, its strange that your vibration doesn't come till 70mph. From what I hear most SC's start vibrating from 60mph.
1) Wheel Balance
3) Wheel Bearings
4) Tie Rod Ends
Originally Posted by jpvarghese
The car just hit 67k; man do I drive this thing alot. How can you tell if a bushing is going bad?
