getting a weird clicking noise/feel in brake pedal/steering
Old 09-01-05, 09:27 PM
Cannonbear
Cannonbear's Avatar
Default getting a weird clicking noise/feel in brake pedal/steering
i had the lower ball joints replaced as well as outer tie rod ends, got an alignment and some new wheels and now i feel this slight clicking noise in the brake pedal when braking and when i turn, its like a click in the steering column. any thoughts? could it be from the LBJ install?
Old 09-09-05, 06:55 PM
rcyo1
rcyo1's Avatar
was the noise there before all the new suspension parts/wheels? who did the install? sounds like something may be loose.
Old 10-04-05, 09:29 PM
clivej
clivej's Avatar
Hi guys,
I am having the same problem now, car has 113,000 miles, never had any suspension work done, then one day this clicking sound appears in the left front wheel well. Happens when i brake and/or make right turns. Since then i have replace tie rod end and upper control arm, problem still exist.
Any ideas what the problem could be.
Thanks
Clive.
Old 11-08-05, 04:13 AM
2jzfanatic
2jzfanatic's Avatar
Originally Posted by clivej
Hi guys,
Thanks
Clive.
I have just driven my car on business this last few weeks and put around 3300 miles on it. The car did great the whole time until I pull into my neighborhood after the long journey home. Then the exact same thing lower ds side wheel would tick and click especially when i turned to the right. It has since gone away but I still wonder what it may be.. Any clues?
Old 11-08-05, 04:19 AM
2jzfanatic
2jzfanatic's Avatar
hmm with a little more research, i ran across this post.. https://www.clublexus.com/forums/sho...t+end+clicking
There is a tsb on it and it makes some sense for my situation, because my pads started to squeal a bit lately....
LuvmyLS
06-27-18 07:54 PM
albertldee
12-11-13 08:20 AM
AnimalB
Suspension and Brakes
09-25-12 07:48 AM
Redpaste
03-10-10 10:35 PM
Quick Reply: getting a weird clicking noise/feel in brake pedal/steering
