quick question about lowering and camber
im a bit unsure of the meaning of this quote from intellexual.net:
does this mean:
if i lower less than 1 inch the camber will stay within spec?
or
if i lower less than 1 inch the camber will go out of spec, but can be correced back to within spec without the need of aftermarket camber plates?
what im trying to figure out is if i lower on stock supra tt springs (around .5"), will i need to get an alignment afterwards?
Anytime you lower the SC suspension beyond one-inch, the factory alignment bolts are unable to fully compensate and you are left with negative camber.
or
even after dropping by only .5"? i thought camber plates were needed for more extreme drops like 2"
Also, camber "plates" cannot be used for our cars. Camber kit bushings made by Daizen can be used to correct the camber for our cars http://www.tmengineering.net/suspens...zen/index.html
