My drivers side was over 1" lower than the passenger side (SOLUTION)
well fixed the issue today right after i got off work. before the driver side was about 5threads higher than the passenger side on the coilovers. now that i made both side of the endlinks face up i noticed that both sides are even now. well almost. the driver side is still about 2-3mm lower than the passenger. better than before 3/4inch.
what's up mike. yeah, i decided to just to have todd do my rear bushings. i've been real busy, so i just wanted him to do it, especially since it seems like people are having problems with the installation. todd did a good job with it and my car doesn't squeek anymore. i like my car 100x more now than i did a few weeks ago. i also put in some tokico shocks with one of my buddies.
Well I checked my rear endlinks because my drivers side is lower than the passenger side, but both are in the up position. I didn't get a chance to look at the ones in the front, but could that also have an effect as well?
My drivers side front tire rubs like crazy, but the passenger is ok.
i think the wrong positioning of the end links didn't lower my car. and because one was up and one was down, it interfered with the shock assembly and it raised one side of the car. i wouldn't suggest moving the end links out of the position that it's supposed to be in.
Originally Posted by actuary
The repair manual shows them like the red line you have in your picture.
hey bro im about to fix my car this weekend, i just removed both my rear tires and I'm gonna check it out, i have no finger gap on the drivers side and like 3 or 4 gap in the passenger side, I hope I fix it, i'll check back here and let you guys know the results.
pilip99, what happened man? I think I have this same damn issue now.
I was driving into this strip mall last night to get some food and I had to kind of angle my car up the driveway because it was steep. I'm guessing this loaded up my driver's side suspension and next thing I know I hear a "thwang!" and I'm like "wtf?" so I park and get out to inspect my car. I immediately notice that my driver's side is slammed and my passenger side is riding about an inch higher than it was previously. How did this happen??
This morning I jacked my car up and looked around and didn't see anything strange so I lowered the car back down to the groubd and now it seems fine. I'm wondering if by jacking the car up it allowed gravity to pull the wheel back down and free up the sway bar from the strut. I guess this weekend when i have the time I'll get back under the car and flip the endlinks around like Howie's are now.
Howie, hit me up if you're free this weekend. I just want you to take a look and tell me if it's what we think it is
After I repositioned the swaybar links to the up position for all 4 corners, the result of lower driver side and higher passenger side is "still the same". Nothing changed as some of you have mentioned. I also carefully tried to find the solution. Both front links have to be the same "Up", otherwise, they wouldn't fit the sway bar. Both rear links can either be the same "Up" or "Down" at the same time; otherwise, they wouldn't fit the rear swaybar either. So it's not like one link on this side is down while the other link on the other side is up. There's no way the links will fit like this. With the same link positions on both sides, they should give equal height. However, they're not equal. So I thought the problem is the swaybars themselves. No bushing problem here because I replaced all new bushings. After the car is driven for a long time, the swaybars are somewhat "bent" and "twisted", which make them "not even" for both sides. The solution for this could be a height adjustable coilover or new swaybars. So does anyone think like this?
Hey Mike what's up man, i was able to fix it. I found out my bushings were pretty much fried, and my swaybars were installed improperly, once i got new bushings and reinstalled the sway bars the alignment was proper now,
Howie, hit me up if you're free this weekend. I just want you to take a look and tell me if it's what we think it is![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
i think it might be worn sway bars i have the same issue with my sc at first i had cut springs and busted driver side shocks changed them out with tanabe springs and tociko shocks .i noticed when installing the shock that the sway bar on the driver side was much easier to go in place compare to the passanger side never looked at the endlinks .but after reading on this thread it might be our swaybars are worn .im gonna take a closer look into this when i get home later .i'll let you guys know the verdict with my swaybars ,maby it can help you
