GS owners with Tein CS-What # stiffness set do you use?
Originally Posted by chuckb
thanks Rich- why do you run the front stiffer than rear? is it because there's more weight up front?
That is what is more comfortable for me. I have used all different settings and this one seems to be the best all around. I used to keep it at 0/0 when I had the WIN kit because the kit was so low. There really isnt that much of a difference in ride as the 0/0 still is pretty comfortable. I also put it two clicks softer in the rear because of the recommended settings in the manual. Not sure if it needs to be like that but it works for me
just a question for all u tein guys out there... when changing the settings, should the dial be set to the max setting (0), and then go backwards? or can u just start from wherever u were set at?
also, is there something to tell u that you've gone past (0) or (16)?
The One
The One
there should only be 16 clicks? the reason i'm asking is because i count 18....!
For another point of reference, the EDFC unit calibrates the same way. It goes full close to get the only reference point it can get, then goes to your desired setting.
Originally Posted by Neo
That is the point. It does NOT stop at 16. This is why (if you are unsure in any way what the setting is) you go all the way clockwise to close the valve. This is stiffest. The softest is 16 clicks counter-clockwise from the close position. You can go beyond 16 but it is not recommended. According to the instructions, it is actually harmful to go beyond 16.
i have mine at 8/8 right now but i'm installing my edfc saturday and i'm most likely setting up the 3 presets as is:
1 - 0/0
2- 6/8
3 - 14/16
there's another thread about this exact topic here also...
