View Poll Results: which coilovers are the best for the 2nd gen gs
teins
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
85
70.83%
bilstein pss
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
35
29.17%
Voters: 120. You may not vote on this poll
teins cs/flex/ha or bilstein pss
#31
This is a difficult poll unless someone has owned both of them on the same car.
That said I have.
Search for my impressions on the two as it is lengthy to repeat.
Currently the PSS are on the SC430 and thus far I am very happy but will know more once the alignment is completed.
Lee
That said I have.
Lee
#33
Originally Posted by TLW
I used to own FLex
I truly hated it .
Ive driven in Jrok car's and he has CS. They seem better than the Flex![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
What's the reason why you hated it?
I own Flex Coils and i don't like them too?
I'm just wondering if you have same issues as me?
#34
Master Thread Closer!!
Originally Posted by DaveGS4
My advice - if you want to slam your car to the ground (all the time or for shows) or have the flexibility of changing the dampening from inside the car (EFDC option), get the Teins.
Can PSS slam the ride?
#35
Originally Posted by PHML
Tein CS at the lowest setting....is about 1 finger gap on 19s....if you want lower...then the other Teins may do that for you.
#38
Originally Posted by DASHOCKER
The max on the PSS is no finger gap cranked all the way down. But, the car will not be slammed to the ground.
#40
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Originally Posted by Mrbig
Anyone with my questions ???
#41
I have the Tein Flex coilovers installed and I like them, however I have driven in vehicles equipped with Tein CS and I must say I love them!
They are quiet and not as noisy from the inside of the car as the Flex. They allow you to drop your car as low as the Flex and provide you with the comfort of luxury as well!
If I had to do it all over again, I would get the Tein CS!
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#42
If I had to do it all over again, I would get the Tein CS!![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
#43
Check out this post on spring rates, softest to hardest.
https://www.clublexus.com/forums/sho...threadid=43181
Tein CS: 9/8
Tein Flex: 10/9
Bilstein PSS:12.25/8.17
Tein HA: 14/10
Tein RA: 18/12
Tein CS: 9/8
Tein Flex: 10/9
Tein HA: 14/10
Tein RA: 18/12
what's the standard spring rate for the GS?
#45
Flex def. go lower than CS. From personal experience, the Flex WILL get noisy over time. The Flex are stiffer than the CS and may handle a little more on the sporty side. If you want a car that rides like a BMW then go with the CS. They are not too stiff for daily driving and they don't make any noise, unlike the Flex. Personally I like the CS, I could go for a little bit less body roll but that can be fixed with sway bars easily and you won't lose your nice ride.
