Alignment Question
Old 10-10-05, 06:29 AM
beaterKU
beaterKU's Avatar
Default Alignment Question
So I am debating with my local alignment guy about this. Does aligning the car with the stock 17x8 wheels and then putting 19x8.5 +45 & 19x9.5 +42 change the alignment specs? In my mind since the offset and width is different, the alignment would be different. What is everyones take on this?
-Nick
Old 10-10-05, 01:05 PM
LexusIV
LexusIV's Avatar
Location: A middle sized town in the middle of the Midwest
I'd say I have to agree with you, it just makes since that the alignement would be different. But I'm by no means an expert.
Have you tried anouther shops opinion?
Old 10-11-05, 06:26 AM
beaterKU
beaterKU's Avatar
Does anyone else have any insight here?
Old 10-11-05, 09:36 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I was told that yes it does change.... By going from 17's to 19's or 20's the camber will change from what i heard... I just had my car aligned and they said the specs where way off and the car drives great now.... When i got the wheels they came balanced so i just slapped them on like everyone else does and the ride wasn't great... But now the alignment makes all the difference.... Good Luck
Old 10-12-05, 05:39 AM
joshoowa
joshoowa's Avatar
its probally not as bad as lowering the car a few inches before/after u do alignment... but yes i do believe it has a small effect on ur alignment.
Old 10-12-05, 01:12 PM
DoubleWhoosh
DoubleWhoosh's Avatar
-Nick
It would change ever so slightly due to different tire shape and height, but an alignment for the most part is done in relation to the car itself and the relationship of the 4 wheels to each other. The wheels of course are bolted directly to the car, with the only change being the play in the ball joints and bushings and bearings.
When your camber is set, it is in relation to where the car is sitting with the suspension at it's normal attitude, which is determined by the wheels (which again are for the most part fixed in relation to the car). The camber won't change for the most part unless you put a drastically deformed or different shaped tire on there.
Same goes for the toe and caster settings.
The only time it would probably not be too good is if you aligned with very worn tires, and then put on some new ones. But alignment with good condition stock tires, then changing to something else should not be any problem at all.
tc1728
09-17-16 12:38 PM
Legender
05-24-13 03:39 PM
neomedic
Suspension and Brakes
02-11-12 10:25 PM
ktang235
02-13-06 06:25 AM
Blue98Gs3
12-29-03 09:33 AM
Quick Reply: Alignment Question
