Emergency brake light stays on
My emergency brake light stays on after taking the e-brake off. My brakes work fine and all of the fluids are full. My front calipers were replaced about a month ago.
My 2nd problem is, when I hit the brakes, I hear a load popping sound from the front drivers side. Does anyone know what this may be.
thanks.
thanks.
That's usually the sign of low brake fluid- as the fluid sloshes around on a hard turn, the level sensor is triggered. If you are sure there is enough fluid, then maybe the sensor is faulty- try overriding it by disconnecting the plug that attaches to it and jumpering the two wires you see in the plug.
Chronolick
Suspension and Brakes
03-12-13 05:07 PM
kwatt1
10-31-11 07:07 AM
Emilio253
SC- 1st Gen (1992-2000)
08-04-10 12:15 PM
