Car still pulls to the left/right even after bushing intall
I have 92 sc300, I just replaced all bushings up front even the steering rack bushings today and the car still wants to pull hard to the left and also to the right (depending on road condition). I'm thinking it could be my front tires, they are worn a little on the inside. I had the car aligned after the bushings were installed but didn't seem to help. What could it be?!
Did you check your engine and transmission mounts?
What bushings did you install, aftermarket urethane or OEM Rubber (Vlamos Bushings) ?
Did you replace all the front bushings? both upper and lower front and rear ?
Did you get a printed readout of your alignment from the alignment shop? were they able to align to Lexus Specs ?
Even if your tires are worn badly if the alignment was done proper you should not get pulling to either side,
Most important question above is ---What is the mileage on your SC.
Engine and trans mounts usually need replacing at 100,000 miles.
Answer the above questions and perhaps we can point you in the right direction to solve your problem.
Rob
Originally Posted by setwire
What is the mileage on your car?
Rob
Rob
Originally Posted by TurboTeg
yep
Wide directional tires will pull no matter how good your alignment is.
I did my bushings with the Daizen ones and mine does still follow the road. Not as bad as it used to.
I have GS400 rims and directional tires on my car so yeah... it does that too.
So do Supra owners have this problem as well?? I was driving around today and definately noticed that when I would be on smooth recently paved streets that a lot of it would go away. We have crappy roads here.
VJ RC51 do you have the same occurance? I see that you also have supra wheels.
Yep. Ive had cars before with wide front tires before, so im used to it
markdav801
01-17-18 10:56 AM
BayAreaLex
11-05-12 03:59 PM
Kyle Harty
02-08-12 11:21 AM
en11871
02-26-08 08:27 PM
