Air Ride Suspension: Need Advice
Why did you go with the chapman struts instead of the air over shocks? Do you think there will be clearance issues with the air over shocks in the rear? thanks for your input!
Originally Posted by V8_Aristo
They didn't have the air over shock units yet when I bought my system. I do think there's going to be a clearance issue if you try to mount the bags close to the rear top mount since I already had issues with the chapman sleeves. A good solution to this would be to mount the strut assembly upside down so the actual bag would be closer to the bottom mount (not as hard as it sounds
). Good luck!
I know i can mount the AirOver Shocks upside down and order that end with a "stud adapter" instead of the eye mount, but how would i attact the mounting bracket from my old shocks on this one?
Well that explains why the OEM strut/springs on the rear are upside down (coil spring on the bottom). So what did you do to overcome this?
Originally Posted by rgarjr
How smooth of a ride do you get out of those sleeve struts?
My next set of bag are going to be the Aero Sport Bag from Universal Air Suspension, this is a convoluted bag with a hole in the middle. I will be fabricating this to my coilovers for a "best of both worlds" suspension.
EDIT: This will also work with factory struts, just remove the factory springs and modify this in it's place.
![](http://www.universalairsuspension.com/store/images/Picture-022.jpg)
Isn't this bag setup for use on McPherson type struts only?
Would you advise going with the Air Over shocks or this Universal bag over some L-Tuned shocks?
I would advise Air Over shocks to someone that will not be using the Aero Sport bag with coilover, for the simple fact that damper adjustabilty is important.
