ABS not engaging?
I upgraded to LS400 brakes and I have a couple of problems. First, I need to push the pedal down alot to get some braking action. I'm guessing I need to bleed the brakes again? Second, on a hard stop, ABS doesnt engage and the brakes lock up. Any ideas?
i think that you have air in your system you will be suprised what can happen if you have air in ther. i say bleed it again and then try, if abs still doesn't work maybe something electrical but never really heard of that problem good luck
