I want to go lower!!!
The One
If the L-Tuned shocks are not too old, it should be fine. As for drop, i actually don't think it will be much more. I think the Espelir drops either 1.7" or 1.9" in the front. I can't even remember the rear specs. The DFs for the GS400 is 2.0" front and 1.5" rear.
The interesting thing of note on the Tanabe specs is that the spring rates for both the NF and DF are pretty much the same. There is a .1 difference in the rear. The spring construction is a bit different to allow the DFs to go lower and maybe that is contributing to the slight additional harshness in the DFs.
ps, the ride is no where near harsh! I sold my DF's to a member here named sfkid
If you want a second opinion, try pming him. good luck.
whatsup funguy! :D
Lexism, funguy hooked me up with his old springs cause i didn't want to spend too much, but wanted low and somewhat comfy ... since he ran them for a while, the spings were prettle settled. The car is very very low. I use the description that rominl (henry) and other use here.. it is zero finger gap. you can kind put your finger between the tire and fender at a 45 degree angle, but that is all, running 19s.
I never took any decent pics, but here is a side one to check out.. I have 19s with Falkens St115s, with Ltuned shocks (kybs). The ride is like almost stock except, say minus 15%, for medium large and bigger bumps in cali freeways. When driving in mucked up San Francisco streets and construction areas, it is noticeable and bottom out once a while. Yep, I have the bumper stops cut in half. Although, I notice bumps more when driving than as a passenger. Overall, it is smoother than I thought it would be, and the 19” ST115 are more comfy than 17” Mich AVS.
To compare to other types of cars… I drive rentals across the western US all the time, and my car is more comfortable or solid than Hyundai Sonatos, Chevy Malibus, Chevy Caprice, Mazda 6, Mazda 626, Nissan Xterra, Nissan Pathfinder, Toyota 4 runner (but not highlander), not as floaty as large Lincolns and Camrys. List goes on…
wow if you bottom out w/ 19's.....imagine w/ my 20's
i have to think about this
your car looks clean though
acutally you have less chance of bottoming out with 20's because they really do make the car a bit higher... when i moved from my 16's to 19's, i didnt scrape as much at the same height but my stocks were a bit smaller with the tires... so if you got 20's i wouldnt be as worried..
Originally Posted by DruMnBaSS
airrunners man!!!!! only problem i see with "performance driving.. is bottoming out on front fender while turning.. happened to me ..
XBS1
Suspension and Brakes
12
12-08-05 02:53 PM
