Possible wheel bearing failure?
So, within the last week or so I have had a slight shimmy in the steering wheel when applying the brakes at higher speeds (55+). I have Brembo Sport drilled rotors that are less than 6 months old. I have allways torqued my lugnuts to 75 ft-lbs so I don't think my rotors are warped. There is also no pedal undulation at all which leads me to believe that there is something else causing the steering vibration. This leaves only a few items to be the culprit, the wheel bearings, tire rods, bushings or a combination of these.
Anyone have any insight here?
-Nick
-Nick
Originally Posted by beaterKU
So, within the last week or so I have had a slight shimmy in the steering wheel when applying the brakes at higher speeds (55+). I have Brembo Sport drilled rotors that are less than 6 months old. I have allways torqued my lugnuts to 75 ft-lbs so I don't think my rotors are warped. There is also no pedal undulation at all which leads me to believe that there is something else causing the steering vibration. This leaves only a few items to be the culprit, the wheels bearing, tire rods, bushings or a combination of these.
-Nick
-Nick
I now use ceramic pads, they are much better.
Originally Posted by Adam2562
wut do you gyus know about re-surfacing slotted rotors? i've heard mainly that u cant.. but i've heard from a couple ppl that u can... any of you guys know?
Ok, I think I might have found the problem. I think I have an inner and/or outter tie rod end going out. I am getting a very audible "pop" when I turn the steering wheel a little and when I go over a curb slowly. It has been getting worse over the last week. The car now wanders all over at highway speeds. I am taking it in asap to have it inspected.
The sacrifices we make for good looks. I am pretty sure that my 19's have expediated the failure of the tie rod along with a set of ball joints a few months back. Oh well, at least it looks good when it breaks
SerasLibre
11-15-10 01:23 PM
