Daizen camber bushings?
No. The Daizen Camber Kit replaces the UPPER control arm bushings. The hole in the bushings is off-center, so depending on how you install the bushings you can get up to 2 degrees of camber adjustment. The camber kit essentially makes the upper control arm a little longer thus pushing the top of the wheel out (away from the car). When our cars are lowered, the top of the wheels get pushed in (towards the car). Instructions are included with the camber kit.
Hope this helps.
Hope this helps.
yea that's the only way. when i went to get my suspension tuned, i asked if they could rotate the camber kit so that i could max out the bottom and have the top being the adjustable portion (i wanted the top to tuck in more so because of rubbing issuse). the tech saw it was a press in and the only way is to remove and reinstall, trial and error until the alignment is right on spec, but this would take a lot of time and since labor = $, i opted against it and ended up shaving/pullin my fenders instead.
