steering wheel vibrates when brakes are pressed.?
Better yet, new rotors. Turned rotors are thinner and warp faster. If you can afford it, get drilled and slotted. If not, standard will be fine and last a long time. Longer than OEM. It should be about $35 to $50 for each standard rotor.
btw- I thought slotted or drilled rotors warp more easily than solid oems.
Originally Posted by chuckb
my rotors were warped when I bought car, after they were turned they have been perfect since(1.5 years)
I agree with ChuckB, also drilled & slotted rotors appears be not effective beyond standart one cuz there is less braking power surface. I also think that's better idia if you get BBK 4-6 pot unit and use drilled/slotted, design to work well with such rotors.
My advice for you: Plain standard aftermarket rotors, bit better than OEM and some good .ss brake pads, unless you do TRACK stuff, than BBK only
Just don't waste your money, not worth it - In My Opinion
RA073123
RX - 1st Gen (1999-2003)
09-05-08 02:53 AM
