Which Big Brakes are the best for the bucks?
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Originally Posted by chuckb
is the supra setup heavier than stock?
Oh ok, here's one of the posts found by searching for 'supra caliper weight'
https://www.clublexus.com/forums/sho...caliper+weight
Originally Posted by Pearlpower
Rotors are a little heavier. Calipers are about the same. Braking difference is dramatic. However based on your post you may just want to go with better pads such as Hawk HPS and some rotors.
Lee
Lee
and lee, i have the hps for my ap racing right now as well. man i love those stuff! it's really right in the middle. not much brake dust and braking is very good!
Originally Posted by rominl
yeah, the calipers alone they are about the same between stock and supra tt.
supra tt brakes sounds the best for now. i would love to get som AP Racing BBk... but their not in my budget at the moment. i still need to get rims before i get some brakes.
i learned so much about bbk's thanks everyone
Originally Posted by DaveGS4
IMO you can get 85% of the performance of big brakes with upgrades to your OEM system (high end pads, synthetic fluid, stainless steel lines)
Originally Posted by jonathancl
Pads, fluid and lines make that much difference? When you do lines, do you need to do all four?
and yes, especially pads, they made HUGE difference
personally i have tried pigid racing pads, then ebc green stuff, and now i am on the hawk hps. the pigid racing pads are really for racing, when it's cold, the brakes are stupid -- they don't stop, but when they are warmed up, they stop crazy. but they eat up rotors like no tomorrw too. the ebc green stuff are ok, braking power was much reduced, but much less dust
i have the hawk hps now and i have to say i love them the most. good performance warm and cold (warm is better of course), and almost no dust as well. that's my new love
and about fluid, i have the motul 600 fluid (stillen recommended them when i got my ap racing). good stuff, i don't have problems, and from what i read they are among the high end list
rotors don't really play role (given the same size) in breaking, however, you need good ones to withstand the heat and also the friction from the pads. put on a bad one and it gets too hot and doesn't dissipate heat fast enough causing warpage. also aggressive pads will cut into bad rotors way too fast and also cost warpage.
that's why if you get good pads, you need to get good rotors to make sure they are "matching"
and 2 piece rotors in general are better for couple of reasons
1) they are usually lighter (for the same size), since the center part is made of aluminum (the hat) so it's lighter than one piece
2) if designed correctly, it also helps to dissipate heat faster
oh and before you ask, personally if someone come and tell me they want less expensive upgrades, i would really suggest BLANK brembo rotors, good pads, and ss lines. yes, blank rotors. imho slotted and drilled, they are more for look and doesn't really do that much for street use. might as well spend less money and get good brembo blank rotors for like 60 or 70 bucks. it goes a long way
Henry, so do u think I should keep my OEM calipers and upgrade them or I should get a new BBK kit?
