Popping in front left...
(Yes I search but seems different)
Just lowered my car with supra tt tanabe gf210 springs and kyb agx struts. Had it aligned and double checked all bolts. having a popping noise from left front BUT also am feeling the pop by my feet. This is over bumps except on the freeway. I dont remember running over any kids so there cant be someone under there hitting below my feet. so I am thinking end links is cause sway bar to move??? I dont know any idea??
Thanks.. gonna go do some searches on ball joints. I wonder if its the ball joint how long it will last before it dies.
Check your end links I had the same problem on the right side. Two new end links it all it took.
see thats what I was thinking, but what do bad ones look like??
Sad took it in today and all endlinks and balljoints and bushings are fine.. They dont know why its making the popping noise still. Looks like I am going to take them off.... there went 2 hours worth of work.
check for fluid coming out of your shocks, every once in a while a new shock will be bad from the factory and will make that sound. i personally have gone through that with agx's.
did you check bolts for poper torque. it has been a problem for a couple memebers where the bolt has backed out a little bit and has caused the popping noise on control arms and calipers. also make sure that your wheel is centered on the hub and torqued down.
MASSMINI
RX - 1st Gen (1999-2003)
02-13-12 04:14 AM
Trouble-T
Suspension and Brakes
07-16-08 12:18 PM
