PS pump replaced still no power
I recently replaced my old power steering pump with a reman after more than a year without power steering and the power steering still doesn't work. I'm thinking I have to replace my rack. What causes a steering rack to stop working? Anyone else had this problem?
I think I may have the same problem. My steering is a bit tight...like I have little power steering. I notice it the most after I've driven about 20 miles at high speeds...say over 65mph, then when I take an exit, I have to turn the wheel really hard to make it. Then sometime when this happens, all of the sudden the steering will break loose and be fine...well better than getting a forearm workout. It goes back to the one step better than no power steering level.
I had my SC400 in a shop that specialized in Lexus for this. They said there was a filtering screen of some sort. I can't remember where it was located on the car, but its didn't take them any time to clean it out. It didn't solve my problem. Maybe it would solve yours.
I've recently purchased Front End Lower Control Arm Bushing from Andrew Vlamos in Austrailia and getting ready to install them this next week. I also bought rack bushings that he suggested. I'll let you know if this solves my power steering problem.
I want to share my experience with the power steering to see if it Might apply to your situation.
We all know about the High Pressure P/S hose. Well, there seems to be another small hose in the same area going either into or out of the P/S pump. It is a short hose but cost $20.00 to buy at Lexus. My mechanic replaced it because it was leaking. When I first got this car (1992 SC400), it had what I thought was power assist in the steering. After Shannon replaced this other hose, I now have true power steering. When I got the car back after this change, I had to re-learn how to steer it. The P/S is Very sensitive now.
Is this your problem?? I do not know and I am sorry that I do not have more precise info, but since you are working in that area, I suggest that you replace that other hose also.
Thanks for the input. I'm pretty sure its not a filter screen or the bushings. I had all my front control arm and rack bushings replaced the other week and that fixed the loose steering I had but I still have a slight play in my steering wheel. As far as the power steering hoses go I don't know how similar the setup is on a SC4 compared to a SC3 but I'll probably look into that. Anyone else have any experiences of no power steering with a perfectly good pump?
CompuMan what hose was this that you are talking about? I just replaced my pump and hoses, but the power steering is still not as sensitive as my friends ls400. Could this hose help?
Hopefully that helps
