can pirelli tires cause vibration when braking?
I also have Pirellis P6. I can't say that tires make any tapping, but they are definetily noisy and don't have a good grip with the road. My car floats on them much more than it did on stock. So, I'm waiting when they finally get worn out, so I could get Michellins or BFGoodrich.
Gsoup, AZDesertGS and GSquicksilver are on the money on this one. Cupping is a sure indication of bad shocks. Believe me, I've been doing a TON of research on this over the last month or so. The old bounce test really doesn't work anymore on today's cars. Also, just because a shock isn't leaking doesn't mean it's not bad. At 80k, you're probably due for new shocks. I don't mean to generalize because I am sure there are 80k mile cars out there that don't need new shocks, but shocks are a wear item like tires, brakes, etc. Unfortunately, you won't know for sure whether they're bad until you get them off the car, but given the symptoms you're describing, I'd bet at least 2 are shot.
Hey, GSquicksilver. Could you please shoot me a PM about your experience with the new shocks? I'd say you could post it here, but I don't want to hijack the thread (although I think everyone would benefit from the information). Thanks.
e
e
a broken wheel bearing does not sound like road noise...it sounds like metal on metal... really loud especially when you turn. it does not sound nice...
The pirelli p6 are very noisy tires... I have them on my LS and the car is noisy... can hear road noise.. it does not provide a lexus like ride either...I'm starting to have a vibration probably because it is cupped so bad that it is now unbalanced. you can research this about these tires on tirerack.com... and this is the main concern with the p6's.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Originally Posted by GSquicksilver
i had cupping before and it ruined my michelin pilot sport s/p's.
it WAS caused by bad shocks. no leaks, nothing. took the shocks out, i can press them down with my thumb. installed new shocks, no more cupping, and i have PIRELLI tires too, pzero nero M+S models and they are great. they are even quieter than the michelin's.
i'm dead serious about the shocks. no leaks. passed bounce test. our stock springs aren't as soft as everyone thinks. when i pressed the shocks down, they were so easily pressed by one finger and they actually made squeek noises too.
I still think its the shock as mentioned earlier ... if your on a budget go with the KYB GR2 series ...very good shocks... the l-tuned shocks were KYB's rebadged for those that don't know... you can get all 4 for about $400 bucks..www.sparkplugs.com
they're gas shocks by the way...
front 2x $92.49
rear 2x $103.40
front 2x $92.49
rear 2x $103.40
If you travel at 65-85 MPH...vibration = tire issues (out of round,cupping, high psi)
If you travel 65-85..start braking...vibration = front brake issues (warped rotors etc)
If you travel 10-35 MPH...start braking....vibration = rear brake issues
Bad wheel bearing sounds like...when you go over a metal bridge..noise "drone-like"
hope this helps.
hope this helps.
hope this helps.
hope this helps.
I would add to this that vibration through the steering wheel is usually front rotors....
vibration through the car is usually the rear rotors
hope this helps.
hope this helps.
The Final Answer:
shocks => supposedly fine
wheel bearings => no reason to suspect problem
(cupped) tires => not likely they were causing the "brr brrh braking vibration" noise.
rotors => all 4 worn. rear rusted.
The sequence of events (and $$$$) over 2 week period:
- 1) Lexus did a scheduled svc and said shocks were fine. they again note the cupped Pirellis.
- 2) I get tires (michelin pilot exaltos, std 215/60/16) and alignment - thinking the problem would go away - NOT!
- 3) after going BACK to Lexus, they identify rotors: Front rotors were below spec {they'd JUST been turned - by mechanic who'd diagnosed wheel bearings as issue - which never made sense}. Rear rotors couldn't be turned at all. Lexus didn't recommend brake pads b/c pads were so new.
So, with 4 new rotors, there's no more "brrr brrh" braking noise/vibration.
SAD FACT: lexus dealership had stated brakes/rotors were fine in prepurchase inspection last summer, then again during the major svc this April 2006. Their "out" was in having no specific prepurchase checklist last summer/fall.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
JTS06Z06
15
10-23-10 04:07 PM
