Daizen OEM Sway Bar Bushings
the improvement should be pretty big. the car should have a lot less roll.
and i am not sure if it's going to help the vibration at 65mph though. that's more like tire balancing and control arm bushings
Originally Posted by GSquicksilver
how many of you are still using OEM sway bars but have upgraded to the Daizen sway bar bushings? my car has about 125k miles and i've noticed that my oem rubber bushings are quite hard now. i was thinking of trying these Daizen bushings, but would like an opinion from those who have them on their car. my questions are:
1. do they make noise? (ie. squeeks, creaking)
2. how is the handling compared to the oem bushings?
3. do the make the ride more harsh?
4. any other problems come up after installing these bushings?
thanks in advance
thanks in advance
To answer the questions you posed:
1. when properly lubed no noise as compared to stock.
2. as stated above a subtle improvement but worth $30
3. No change in ride quality. Even stiffer sways will not adversely affect unless you go overly stiff ie. such as a full race type sway bar.
4. Have not experienced any negative effects in either vehicle attributable to stiffer sways or poly swaybar bushings.
Rom is right, contact Todd first by email or phone to set up a time to meet. He is essentially a one man operation and does not keep 9 to 5 hours 6 days a week. Best to make sure he will be there when you show up.
BTW, when I bought my sway bars from him and he was doing a timing belt change on my car, he installed the sways for no charge. That was a nice added touch I thought.
Originally Posted by rominl
the sway bar ones, or the control arm ones
Originally Posted by GS430lvr
The sway bar ones of course! The Daizen Bushings for the control arms that Todd just put in better last a long time! I finally looked at his work when I was installing some new wheels...boy does he grease those pup pies up!
I just bought the sway bar bushings too. Next weekend's project. I am anxiously awaiting the anouncement of the NY or DC control arm bushing trip by Todd. I'm not sure of any shops in the area that I trust to do that job. I may end up mailing mine in, but I thought that install back on the car was part of the challenge with the control arm job, No?
just sent todd an email for 2 sets and local pickup. can't wait to pick these up and put them on the car.
