Cusco Type II Lower Arm Bar
Whats up gang.
I am considering buying the Cusco Type II Lower Arm bar.
Planning to go Forced Induction soon, so I wanted to take care of the suspension first.
I have some TEIN CS getting installed in 2 weeks.
Info on the product:
"The Type II lower arm bar features the same tubular high-tension lightweight aluminum design and anti-corrosion paint as the Type I. The difference though, is that this bar improves body rigidity by connecting the lower arm mounts in multiple positions rather than just two, thus greatly increasing the rigidity over the Type I style. Body rigidity is maintained on even the hardest of cornering and dramatically improves steering rigidity, response and traction."
What do your think of it?
Any recommendation?
Any recommendation?
will it work with the TOM's front/rear bracing?
TOM's has front member brace and rear member brace for the GS. Which brace is this Cusco part equivalent to? Or does it replace both TOM's braces?
Would really appreciate if suspension experts could chime in on this.
From my understanding its equivalent to the "Tom's GS lower Front Brace. I know for sure that it doesn't replace both "Tom's braces", just the front. Cusco carries a rear brace.
Tom's: $360
Cusco's : $170
Product Info on Tom's:
"TOM'S front lower chassis brace helps reinforce the front and mid portion of the chassis.
The results, greatly improves the car steering response and handling capability. Material:
Steel with durable powder coating paint."
Originally Posted by Fisher503
Who sells this for the GS?
Napsusa Site
I went through the Cusco Site to find Napsusa.com
Cusco Site
i just checked it out. where did you find the pic? i saw another pic http://www.napsusa.com/cgi-bin/napsusa/187-477-A-.html
can you link us to the right one? that is all i found on that site.
Try this:Cusco Type II Lower Arm Bar Link
Originally Posted by LEXSOOS
Check this out: http://www.vividracing.com/catalog/p...oducts_id/1822
Does this fit GS300?
I've noticed that the only the GS400 and JZS161 models are mentioned.
Does this mean it doesn't fit the GS300(JZS160)?
