How do you spell relief? T-O-Y-O
GS sorry for the incomplete info! What I meant with "upgrade" was specifically on the section width (235). Considerating that they will be mounted on an SC400 '93. I would also like to keep the same factory tire's diameter (tire, not rim!) so I can have the same speedometer readings.No less revs.
Thanks for the advice on tires.
Hey Guys, I am in the process of buying 19 x 8.5 and 19 x 10" wheels and I wanted to go with Toyos this time around. Do any of you guys know the overall diameter of their following tires....245-35 and 275-30. From their website, it seems like there is a huge discrepancy on those sizes. Normally these two wheels should be close, but they are off by a few inches. I am looking for the quietest tire possible. How is the wear on the S-03s? I know that the general tire issue has been covered nearly 1,000x, but the S-03s are new...
Does anyone have experience with the Toyo T1-S and the Bridgestone S-03 Pole Position? Looking for the one with better wet traction (hydroplaning), treadwear and lower noise.
Thanks,
D2-AUTOSPORT
Wheels and Tires Classifieds
04-25-03 07:09 PM
