Lexbox Mods II
#92
Originally Posted by Lexbox
If you are going to do it, do it right. And if they can see it, make it pretty. I swear all of this fancy looking wire and platinum goodies are seriously denting the pocket book but, who wants to see plain ol' red and black wire with gold terminals anymore.
Pictured:
JL Audio XR650-CSi 6.5" Component set
40ft of Stinger 12ga HPM twisted wire
Misc parts
Pictured:
Misc parts
can you write & snap pics of the work in process when you build your front speaker assembly? if you can, a sencil would be great for us who will be upgrading to 6.5 speaker up front. i assume you're going to use the stock mounting points?
#93
This will actually be my second oil change since swapping to synthetic but I forgot to post a pic of the parts.
For anyone that always views this thread when it pops onto the front page, you know that I only post with a pic.
#94
The Xbox will color-matched with the interior pretty soon. Kind sticks out like a sore thumb right now.
Video Part 1 of 3: Come see what put the "xbox" in Lexbox (1 of 3)
Video Part 2 of 3: Come see what put the "xbox" in Lexbox (2 of 3)
Video Part 3 of 3: Come see what put the "xbox" in Lexbox (3 of 3)
#95
1 Post
Following KID_LEXUS's recommendation I ordered the basic color camera on Ebay. I pulled out the lock and replaced it with the camera, Im just glad the lock isnt off-center like my old ES300. I used a AC/DC block from my storage bins. There are two wires coming out of the block of which at first I had no idea which one was power or ground. It turns out the wire with the white striped wire is the hot wire. I didnt find out the hard way though, I simply busted it open and by following the circuit I figured it out. I knew it was the hot wire because the trace ran through a capacitor and they only run on the hot side. I had a small condensation issue that was easily fixed with some pipe tape. The camera only works when I am in reverse but very shortly I will add a diode to prevent the signal from backtraveling and making the reverse bulb light up while I am in drive.
I'm glad you like the camera
#96
The leather badges were added by the dealership. The rear center seat is the only headrest with "Lexus", the rear and front headrests all have "L" badges. Very nice if you ask me.
Very nice mods!
Are those leather badges custom made or oem parts ? does the dealer have something like that ? thx.
#97
New speaker plate using 3/4 MDF. I got away with using the stock screws because I used two different sized bits. I use a 1/2" bit to let the bolt ssit inside the wood and finished off with a smaller bit to allow the end of the screw to reach the stock mounting locations.
#98
Pictured: This is a second JL Audio XR650-CSi component set for the rear. JL Audio 4-channel set of RCA's. And of course, another 20ft of Stinger 12ga HPM speaker wire. The RCA's must have come from a retail shop because there is a sticker that says $119 for the RCAs but Ebay was very kind at only $68. I needed more RCA's because I will finally be adding the AudioControl Four.1 EQ/Line Driver to the system. I just hope I dont blow the stock 10", its doing great so far with 150w RMS.
#99
And here is the final look of the rear component set. I would have liked to mount the tweeter higher but do to the slight curve at the top of the door panel I felt it would be best to mount it where you see it. The flash has exaggerated the color of the plastic but its night time and I wanted to share my progress.
#101
Originally Posted by ebruce2
so you got away with the 6.5's front and rear?? I have the same JL's and I could have sworn the shop I used had some sort of problem with 6.5 being to big back there.
That was a while ago though.
#105
I like to keep an online list of modding activity. So here goes.
Already on:
Yellow Top Optima
SRT Intake / ECU with blue filter
Alpine IVA-D310 touchscreen w/ PAC TR7 bypass box
Sylvania Silverstar 9005 Low beams ( Borrowed the 9006-->9005 mod from the ES forums )
Sylvania Silverstar 9005 Fogs ( Borrowed the 9006-->9005 mod from the ES forums )
Sylvania Silverstar 9005 High beams
Polarg M6's, Polarg M4's, Polarg M16
OBX Clear Sidemarkers
PIAA 7440 reverse lights for old 98+ tails
Black Speedometer bezel
Black Pearl license plate frame
Tripp Lite PA375 inverter
Modded Xbox w/ 320gb
Rotora rotors F / R with Axxis Deluxe pads ( Thank you L-Tuned )
G2 white caliper kit, Black caliper decals
Keyhole trunk color camera
01+ tails with Polarg M6 reverse lights
0-gauge amp kit with tons of platinum goodies
JL Audio 300/4 amplifier
#74 led's in ignition light ring, PNR, footwells, and glove compartment
20" Donz Columbo's( Thank you D2Autosport! )
JL Audio XR 650-CSi component set
Waiting to be installed:
Large sheet of Bird's Eye Maple to make my own real woodgrain kit ( $13
OBX header
AudioControl Four.1 EQ / Linedriver
Torque Master plugs
20ft 12ga Stinger speaker wire
On the way:
4-channel JL Audio Interconnects/RCAs
UGO roof spoiler
CarsonTuned strut bar
Future Mods:
Woodgrain steering wheel ( American Stitches )
JL Audio 1000/1 amp
Resonant Engineering 12".....maybe two
Tein CS coilovers with EDFC
RMM body kit or L-tuned
Carbon fiber hood
SRT Stage II Turbo kit
Already on:
Yellow Top Optima
OBX header
Torque Master plugs
On the way:
UGO roof spoiler
Future Mods:
JL Audio 1000/1 amp
Carbon fiber hood
