Preventing wheelhop - Coilover settings?
Originally Posted by scoarer
Will ajusting the spring preload make it any stiffer?
I've found the hardest setting to be a bit harsh for daily driving on our horrible streets, but you're right, it has done wonders for body roll. It's a good thing that you're getting some dampening at the hardest setting. You don't want it to be completely solid.
~Alan
the difference in dampening is alot more in compressing the shock quickly. youll be able to move if if youre moving it slowly, but try to push with one really strong quick push. youll feel its alot stiffer than when you push it slowly. thats why they call them "shock" absorbers
the spring absorbs and dampens/resists against more of the resonating type vibration. thats why after you go over a bump the car doesnt bounce up and down much.
also, the preload of the springs will affect the stiffness alot. you can only compress a spring so much until it either bottoms out or pushes back just as much as its being pushed on.
i just bought some tein flex too, just to confirm,the ones for our sc's and supra's don't come with camber adjust. plates right? One more thing..how stiff do u like it
in other words, what do u set yours at?
Originally Posted by DETUNED
Our cars use a double wishbone suspension which don't allow camber flates. You can get the JIC upper control arms to adjust camber.
Or you can get some Daizen camber correction bushings, which I have for sale
