Need advice- are tie rods and ball joints a DIY job?
Old 03-01-06, 02:40 PM
bazop
bazop's Avatar
Default Need advice- are tie rods and ball joints a DIY job?
As the title says- can a rookie handle these? I don't consider myself mechanically inclined, but I do like to take care of things myself when I can. I did manage to get the L-tuned shocks and springs on ok, although it took me alot longer than it took others to,based on searching through past threads. So should I try it, and what would I need other than a ball joint puller? thanks.
Old 03-02-06, 07:23 PM
rgarjr
rgarjr's Avatar
I think it should be a DYI if you have the tools for it. Just remember to mark the tie rod ends because you will need an alignment right away.
Old 03-03-06, 08:26 AM
pavster
pavster's Avatar
It's a DIY if you know what you are doing. Here is some help https://www.clublexus.com/forums/sho...d.php?t=153536
KleeNx11
09-09-19 09:29 AM
tither777
07-09-11 06:27 AM
memGS300
Suspension and Brakes
02-22-10 02:47 PM
girlilove
07-01-07 10:42 AM
400 Degrez
19
01-02-07 01:34 PM
Quick Reply: Need advice- are tie rods and ball joints a DIY job?
