Brembo Big Brake Teaser...
Originally Posted by ACleanSC4
how'd you know!!!
I'll unveil the full details if/once it gets finished...oh yeah, the rear calipers are identical to the fronts!![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
If they are the exactly the same caliper, piston sizer & rotor size F & R , then you are going to have way too much rear brake bias, unless you have a proportioning valve.
If that's the case, then this is a real dangerous combo.
There may be a good reason why it's never been done before.
Kids, don't try this at home.
I still wanna see it on the car
Kids, don't try this at home.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Yes, if you don't have a competent mechanic, please do not try this at home...good thing I live in SoCal and Todd is the best one around...
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Yep, Todd's da man.
I know you want to save the full details until after its done, but at least clue us in to the plan- do the bolt holes line up?
If not, do you plan to make a bracket, or drill the caliper and/or hub assembly to make it fit?
