Daizen Help!
I just ordered the Daizen Control Arm Bushing Kit and the Daizen Sway Bar Bushing Kit (OE) (both from lexus-parts.com) and I was wondering...
for the control arm kit: i know it comes with upper/lower/castor arm bushings for both driver and passenger sides, is that all? (i ask this because lexus says i have upper/lower control arms on the front and rear of my car??)
for the sway bar kit: it comes with just the front/rear sway bushings, correct?
also, i was quoted from the lexus dealership that the install on all my bushings will cost me $2,280 + tax and other fees... which is just outrageous
should I look around for different shops? what do I do? what's the average cost on bushings install?
thanks
thanks
thanks
thanks
Wow, that's high. I got a relatively good deal at 350.00 instaleld for the bushings and had the tie rods/ball joints replaced at the same time. Took 6 hrs in labor and well worth the wait... Defintely shop around for the best price.
350 is a fantastic price for labor..... i dont know who would do that around here... its alot of work to change out those bushings.... I know some guys who would prefer swapping out engines.
thanks
thanks
Daizen bushing kit comes for front suspention only, Daizen sway bar kit comes for both front/rear.
over 2K for installation, you better send me $500.00 so i can get mine done this saturday J/K as well
This is way too much man, you should be able to do it all for about 500-600 bucks at the most, look for performance shop in your area or any other auto shops, but not like midas or other franchise shops, they will rip you off BIG TIME
Originally Posted by TexasGS
Man, where in Texas did you get this done at for that price? I would drive most anywhere in the state for that price.
yeah, i'm not goin' to lexus to have the bushings done, lol i'd be retarded :-X anyways, i found a machine shop that's going to do it for me. altogether i'm doing the following:
replace ball joints (driver/passenger)
replace outer tie rods (driver/passenger)
install daizen sway bar bushings (oe) (front/rear)
install daizen uppper/lower control arm, castor arm bushings (driver/passenger)
power flush & refill the following:
transmission fluid - amsoil synthetic
power-steering fluid - amsoil synthetic
brake fluid - motol rbf600
coolant - toyota red
differential fluid - royal purple 75w90
i might also get some springs installed - tanabe nf210's, i think the price is gonna be somewhere around $500 for all that
including the price of the fluids and such.
does anyone know where i can get those fluids? i hope i can find them because i heard they're the best.
Our Lexus dealer quoted $1,200+ to replace the shocks & springs and install the daizen front control arm bushings. The mechanic was kind enough to recommend some other shops that could get the job done cheaper. I imagine they also wanted to replace the entire control arms rather spend time pressing the bushings into place.
We paid $300 to have the S&S replaced, $35 to replace the sway-bar bushings, & deferred the 6 hours to have the control-arm buhsing installed. After a $50 alignment, we are almost finished.
On the drive home, the VSC starting kicking in, so we may have some bonus issues to correct. I'm going to reset the ECU, before having the mechanic check the speed sensors.
Always a few gotchas when dealing with these sensitive components.
Former Vendor
since you're in colorado - i'd drive over to LA in California to see Todd @ TM Engineering. I know it sounds crazy but he also sells the Daizen sway bars that would be better than just replacing the bushings for the sway bars and he does EXCELLENT work. I just had him do a ton of work on my car and everything came out perfect.
