What do I need to replace if...
ok, my steering is tight and as straight as can be about 80% of the i'm driving time in my sc4, but occasionaly the front wheels will jerk out of alignment after going over a small bump or groove in the road. I'll have to wobble somewhat and straighten it back out, then it's fine again.....my question is, is this something cheap maybe bushing replacement or something more expensive like the whole steering rack?
thx
thx
I would start with the steering rack bushings, as that is what it sounds like to me. They are pretty cheap, and should to be pretty easy to install. Thats my next planned repair this weekend too. But you may have other worn out suspension parts as well if you havnt already replaced some of them . IE tie rod ends , ball joints , front LCA bushings etc.
Originally Posted by TMaxxTim
LCA's going bad can cause that too. Both my steering bushings and my LCA's were shot. Get the Daizen ones and either install it yourself (some work), or pay a shop to do it.
there's a japanese auto shop less than half a mile away that i plan on taking parts to
which of these will make a bigger difference given my situation? :
http://www.lexus-parts.com/partdetai...bCategoryID=21
That sounds serious and I would check that problem out asap....Your wheel can move forward and back when reversing and then suddenly braking, that is the sign for worn out LCA bushings...Hiting a bump and wheels go out of allignment is more then worn bushings. I would check your chamber bolts to see if they are on tight and also check all your front end ball joints on your steering control arms...upper and lower. I would not drive the car......Good luck
I hate to keep arguing this, but I disagree that the car is undrivable. While you need to be more careful watching how the car behaves. When my LCA's were worn out my steering did those exact things you described, but they never jolted my car or turned the wheel enough to ever put me near crashing.
where is the best place to start looking for new LCA's? Is there a site where I can buy supra ones?
Oaklandsc3
Suspension and Brakes
12
05-10-16 04:06 PM
cameratoaa
19
08-20-13 09:54 AM
BoostAddct
17
10-28-11 09:29 PM
