TEIN CS Questions
TEIN CS Questions
I just bought these like last month and the previous owner told me that he had them turned all the way to the stiffest setting? I was wondering how I make them softer?
Also, what's the life span on these TEIN's? I heard one member had them for 40k miles, but is that the most or is that the average or what?
thanks
thanks
Suddenly lots of questions about coilover lifespan...
Anyway, I've had my CS for about 45k miles now with no problems of perceived loss of performance.
Check this out:
http://www.tein.com/ti/inst/rt76u.pdf
Check this out:
thanks
thanks
As for how long they last, there is a lot of factors that come to play like how bumpy are the roads you drive on. You can drive 50K w/o any problems if you have nice smooth roads. In the other hand if you drive on bad roads you probably will get less than that becuase they are getting more abuse.
Think of them like brake pads. they all wear out differently depending how you use them. Lead foot = shorter life. Someone who slows down less agressively = longer life.
I hope this makes sense.
Former Vendor
i just wish there was a way to adjust the spring firmness. the dampening is great but the car still floats since it compresses and then decompresses the spring when you go over an undulation in the road.
on my old bilstein/eibach setup - the spring was preloaded all the time so the ride was quite firm. very bmw-ish.
Originally Posted by JeffTsai
Heh, I wish Tein provided a lifetime warranty but their coverage is only 1 year. With how much they are charging for the coilovres I would think they would at least give 2-3 years.
I found this out too about the softness. I was used to driving with the Tein Flex system and I am not use to the softness. I've had mine on the car for 3 weeks and put them up for sale. I'm going back to my old Flex system. Don't get me wrong the CS are great. Less noisy and softer, but it's not for me.
If anyone is intersted PM me. They are practically band new.
Former Vendor
dejacky- the only thing you gain is that you can lower the center of gravity. if you just swap out the tein cs and want to take care of the handling department, you'll have to get some sways to stiffen the chassis.
the tein CS is soft... quite possibly softer than stock but it removes that floating created by the stock shocks rebounding while you go over undulations in the freeway on sweeping curves.
if you're looking for something more sporty- i suggest the bilstein shock and eibach spring combo. make sure you cut your bump stops and it'll ride awesome. cost for that setup - approx 700 new.
The One
Warranty or not, once you get into the 30k, 40k, 50k mileage area, that is just wear and tear. I don't think it is manufacturer defects at that point. As with anything else, you eventually need to do maintenance: replace or refurb.
As for the CS softness, it is different from the Flex. When I first went from the Flex to the CS, I did not like the muted feeling either. I felt more connected to the road with the Flex. The feedback was from the metal to car connection and road noise. As time went by, I learned/realized I like the CS better. It handles much better than stock. It may not feel like it because of the ride quality retention. It is also much more quiet than the Flex. You adjust to the feedback of the CS but I think that is how a luxury sport car should feel. It is quiet yet provide enough handling. I would not fo back to the Flex.
